Thread: Photobucket fix
    Photobucket fix
    I found this on Garage Journal.
    "Hi all, just read this on another forum and wanted to share it here as pictures are so important to sharing info about our hobby. I just copied the post so here it is and it seems to work with firefox for me.
    Fix for seeing Photobucket pics
    If you're using Google Chrome, go to the three dots on the right side of the screen and click them. A drop down should appear. Hover your mouse over "More Tools," and when the next drop down appears, click on extensions. Go to the link towards the bottom that says "Get more extensions." In the search box, type "Photobucket Fix," and hit enter. Click the install button and once it's done, you should be able to see photobucket pictures again.
    For FireFox users, click on the three bars on the right side of the screen, then click on add ons. Click search for "photobucket hotlink" and click install. Same result."
    I am using Chrome. I had a choice of three fixes pop up. I chose the first one. I just looked at an old thread of mine and also EdwardB's build thread and I can see all the pics in both.
    Senior Member stack's Avatar
    Macedon, NY
    tried it. blocked on my work computer
    stack
    FFR MKI Roadster FFR2202K Built in 2000 sold
    FFR Hot Rod #39 under construction
    Louisville, KY
    Wow, great find! I just installed for firefox and it appears the old photobucket photos are now visible again!
    FFR8551 289 FIA build in progress.
    Member Frank Messina's Avatar
    Yorba Linda, CA
    Great find Craig. Thanks for the tip.
    FFR 4440 - V8, Manual Trans, Htr, WSW, IRS. I wouldn't change a thing.
