Results 1 to 4 of 4
Thread: Hot Alternator - Why?
    Tybee Island, GA
    I noticed yesterday that my Alternator was hot while trying to crank my car. What is this a sign of? It's not normal is it.
    Videos are at: YouTube Videos
    Notwithstanding a wiring error a warm alternator when not running is typically indicative of a bad diode in the internal rectifier bridge.
    PS---Please disconnect the battery until you have corrected the problem.
    So Jeff, you mention "not running", but would that also happen when the ignition is just turned on?
    I have heard of certain older Ford alternators shorting internally, even when the car was parked, ignition off. There was a serious potential for a fire, if there was no fuse used.
    Santa Clarita, CA.
    If I have the ignition on without the engine running the alternator will get warm after a few minutes.
