0
0
Dash and Dash Support Position
I am sure this question has been asked thousands of times, but here I go again.
With most of the electrical done, I am trying to make sure my dash is in the right position. I have it placed based on where the dash support connects the bottom of the dash and the transmission tunnel. It sits below the top chassis bow at the middle by 3/8". It is pretty much even with the bow at the edges. See picture below.
In this position the bottom of the dash support contacts the transmission tunnel cover 6 7/8"" from the vertical aluminum piece at the front. See picture.
Again, in this position the dash tips forward at about 30 degrees from vertical.
Does this all seem correct? Am I in the ballpark?
Finally, what is the process for making the curves (bends) at the ends? Thanks. Joel
