Results 1 to 21 of 21
Thread: Hood Scoop
    Senior Member jwebb's Avatar
    Longmeadow, MA
    Hood Scoop
    The scoop that came with the kit appears to be plastic, is there a scoop that's made of the same material as the body? Body shop has concerns with bonding the two together (no rivets).
    For a period correct look, consider a rivet on aluminum scoop.
    If you prefer no body seams, then bond on a glass scoop if you are not a fan of the rivets.
    Hope this link helps:
    http://www.csxparts.com/search.aspx?...m=hood%20scoop
    Also, I'm not a fan of bonding dissimilar materials so I'd suggest getting a glass scoop; however, it may be Polyester instead of Vynlester Resin which are more compatable than glassing ABS Plastic.
    Correct...do not bond the ABS scoop to a 'glass hood. It'll come back to haunt you later. I've found early Mk4 fiberglass scoops (what was supplied for the first year or 2) in the forum classifieds from guys who went scoopless. Try posting a "want to buy" and you might get lucky!
    Aug 2017
    Southern WV
    Factory five still sells a mk III hood with a fiberglass scoop you may want to check and see if the mk iii and iv
    Use the same hood
    May cost more it but would accomplish the look you wanted
    Just a thought
    Rick
    Quote Originally Posted by Itchief View Post
    Use the same hood
    They are not the same.
    No bonding ABS to glass. If you don't find one in the classifieds get ahold of me 951-676-0191 Jeff Miller. I have molds to make the scoops.....just not a lot of time to do it so I don't advertise that fact....well, I didn't until now.....damn!
    Longmeadow, MA
    Jeff,
    Since you don't advertise, if I asked you to make one what are we talking on time and cost?
    Jim
    Jax Beach, FL
    The screws that are usually used are called button head. They are a domed head that uses an Allen key.
    Sent you a PM
    $100, two weeks...da Bat
    Longmeadow, MA
    Responded, let me know
    Longmeadow, MA
    Thanks Jeff, but I found one local and freed up your time!!
    Jim
    Using rivets, what kind of rivets are you using? And if you are using different rivets than the one for aluminium panels, where do you get them?
    Custer, SD
    Quote Originally Posted by hugo-k View Post
    As mentioned before in post 8 above I used button head stainless steel screws and nylock stainless nuts with stainless flat washers under the nuts. The fasteners were acquired from Fastenal. -- Chuck
    Longmeadow, MA
    Now that I have a fiberglass scoop(thanks Mike), recommendations on bonding materials??
    Vinylester resin, fiberglass mat and Rage.
    Note that the scoop is black because it was cut out of a Mk3 hood NOT because it's ABS plastic.
    Senior Member Bren's Avatar
    Dec 2013
    Build: Sugar Land, TX; Live: Madison, WI
    If the scoop will be riveted to the hood, is the plastic scoop recommended or not?
    Build Blog
    #8203, carbed 427W (611 hp), TKO 600, IRS
    Delivered: May 27, 2014
    Mechanically "Complete": October 1, 2014
    Quote Originally Posted by Bren View Post
    I like the plastic scoop---more symmetrical and less lumpy than the 'glass one plus it doesn't need the edges trimmed or the underside smoothed and finished. I do cut back the turndowned lip at the front and use buttonheads and nuts instead of rivets though.
    Longmeadow, MA
    Jeff,
    Appreciate the info, thanks again!!
    Aug 2012
    Grand Rapids, MI
    A slight change, hope no one minds.
    Are there any taller and wider fiberglass scoops? Can one be fabricated? I believe that I'll need to cut a hole of 14 - 15 inches in diameter through the hood to fit my air cleaner. Just curious for now but this will get more important as the build progresses.
    Jim
    Jim1885 ,Shell Valley had a couple of scoops. You might give them a look
