Results 1 to 10 of 10
Thread: Grill mounts on upper control arms
    Oct 2017
    The manual says to put the upper control arm bolts through grill mounts with logo facing forward. What are grill mounts? No picture and grill mounts are not in the parts list.
    Norton, MA USA earth
    You can see it in this picture.
    Oct 2017
    I’m not sure. I cant find any such item in the parts list. Is it something I could easily install later when I figure out what and where mine is or should I stop installing the front end?
    This picture should help you out. Check my build threads for more pictures.
    http://thefactoryfiveforum.com/showt...d-by-wallace18
    http://thefactoryfiveforum.com/showt...e18-s-33-build
    Prairieville, Louisiana
    You can install later if need be. Just loosen the control arm bolts, slide the grill mounts in (they are open end slotted) and tighten back up.
    '33 Hot Rod
    MK4 Roadster
    Oct 2017
    It should be noted. They do not look like the manual shows them to look.
    You can see mine really well in this photo so you know what you’re looking for.
    '33 Hot Rod
    MK4 Roadster
    Stillwater, NY
    Quote Originally Posted by Svtfreak View Post
    The upper headlight mounting holes didn't exist on the early builds - that older style is what you see in the manual. The headlights would hit the fenders if mounted on those brackets so FFR redesigned them with two holes so the headlights would clear the fenders in the upper holes. The full fender package wasn't designed when the early kits were built so the problem didn't show up until later when the fender kits started to ship.
    The ones in the manual also show the mounting holes where it goes on the a arm bolt to be holes and not slots.
    '33 Hot Rod
    MK4 Roadster
    Senior Member TDSapp's Avatar
    Frisco, TX
    Sorry I am late to this thread, I just got back from a trip to Colorado.
    Here is a photo of the grill mounts you are looking for.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
