Thread: no power to OBD connector
    Senior Member dpariso's Avatar
    Aug 2017
    Beach Park, IL
    I want to check to see if any codes are present but when I plug into the OBD connector... no power! I checked all fuses and they look ok. Anyone else have a similar prob?
    Placitas, NM
    OBDII connector should have +12 volts at pin 16 all the time.
    Aug 2017
    Beach Park, IL
    do you mean pin 16 of the plug? which one is pin 16?
    Placitas, NM
    Placitas, NM
    Quote Originally Posted by dpariso View Post
    Dpariso, just saw your post above.
    The way your connector is mounted pin 16 should be the top right pin, just under your pointer.
