Results 1 to 20 of 20
Thread: What to do with the heater hose fitting on the water pump?
    My beautiful Blueprint 347 is getting ready to go into the car and as I was looking everything over, I noticed that I have a heater hose fitting on the water pump. I'm not installing a heater and assume I need to plug this, but I'm not sure if I should just use a pipe plug or is there a better way to do this?
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Maricopa AZ
    Put a heater block off cap on it
    Member Toy4me's Avatar
    Voorhees NJ
    I agree with Gordon since your pump is already on the motor. I pulled the nipple and tapped it for a pipe plug but my pump was not on the motor. Either way will work fine.
    Senior Member jlfernan's Avatar
    Port Orange, Fl
    Woodstock ,Illinois
    In your situation, put the cap on. But keep an eye on it! I’ve seen them crack and fail sooner than you’d think.
    I don't trust those rubber caps and usually drive the nipple out then unstall a freeze plug. The nipples don't come out easily so in your situation with the water pump already installed the cap is probably the only reasonable option.
    Mar 2013
    Fort Collins, Colorado
    I just did this. Knocked out the nipple, and tapped it for a 1/2 inch pipe plug. I did not / would not do it on the engine, it is easy to get it off of the block and into a vise. This is something that I did not want in the back of my mind, positively solves the problem forever.
    Senior Member Gromit's Avatar
    Mass, North of Boston
    I've used a copper pipe cap soldered to a short piece of copper pipe. then a short piece of heater hose to button them together only because that is what I had on hand when a heater core blew out.
    Chris AKA Gromit
    Woodstock ,Illinois
    I put a freeze plug in myself when I changed out my water pump. Think it was 3/4”.
    O'Fallon, MO
    Don't use those rubber caps, they only last a couple years, then crack.
    I used a small piece of radiator hose, capped with a brass fitting from Lowe's... Cheap and easy.
    If the rubber caps don't last long, simply replace it every year, as part of a your maintenance program. Cheap enough..
    I'd suggest an expansion plug, as I have used on my rad for 6 years without issue, hut I'm not sure they make them small enough for what you need.
    I found this on McMaster-Carr. What do you guys think about using tit for the plug?
    https://www.mcmaster.com/#2908k11/=1a14m63
    Legal: 1/30/2020
    Nov 2016
    "The i.e." SoCal
    We prefer the Breeze solution. No flow restriction and still allows you to use the manifold port for a sensor.
    http://www.breezeautomotive.com/details.php?prod_id=464
    Only rated for 10psi, so it might be a little light. There is a similar one I've seen made with silicone rather than neoprene, that might have a higher psi and temp rating.
    This is the solution I'm going with. Thanks for all the suggestions everyone.
    Legal: 1/30/2020
    Senior Member DavidW's Avatar
    Stevensville, MD
    I got the breeze part but found it didn't fit between my alternator very well. I ended up getting this molded heater hose and cut it to fit. It has all the right bends in it to fit between the alternator up to the manifold, part number NAPA 11644, Gates 19644.molded hose.pngHose installed.jpg
    Quote Originally Posted by DavidW View Post
    That looks more professional. I just ordered this as well. You guys are great at helping me spend money!
    Legal: 1/30/2020
    Problem solved! Thanks for the recommendation on the pre-formed hose. It was a perfect solution.
    Legal: 1/30/2020
    Stevensville, MD
    Glad it worked for you. Enjoying your build, keep post coming.
