Results 1 to 9 of 9
Thread: Engine wiring question
    This is off an EJ207 it is from the oil filter area8AA83D98-159D-44FC-8D4A-386DDB7D3F1F.jpeg
    Not sure what they are called to track down on wiring, thanks
    Southport, NC
    I think I've got this right but let someone else also confirm.
    Right screw in is the oil temperature sensor.
    Left screw in is the oil pressure sensor.
    George
    Senior Member alpine227's Avatar
    maine
    Quote Originally Posted by GWL View Post
    George
    Yes left appears to be pressure right looks like temp. I am not super familiar with the ej207 but am venturing a guess that those are for aftermarket gauges as every Subaru motor I have seen has a pressure switch not a sensor. Looks like a sandwich adapter plate installed with after market sensors.
    iWire's Avatar
    Lake Forest, CA
    Quote Originally Posted by alpine227 View Post
    Correct, in Japan you can STi Genome gauges for these items from the factory.
    When we say to our customers "if there is anything you need, please ask," we mean it.
    iWire Subaru Wiring Services
    Over 100 Custom 818 Wiring Harnesses Built
    http://www.iwireservices.com/factory...18-wiring-kits
    [email protected]
    maine
    Well there, I solved a problem only took 3 years!
    Will the sensors work with any type aftermarket gauge?
    iWire's Avatar
    Lake Forest, CA
    Congrats!
    Quote Originally Posted by Chef818 View Post
    Yes it should, however, the calibration of the resistance may vary from gauge to gauge so it's hard to know if it'll read right.
    [email protected]
    Leesburg, VA
    Depends on the gauge but most of them come with their own sensors so you could just replace the ones you have (assuming they have the same threads). Otherwise it sounds like a lot of trouble to characterize the sensors you have and see if they match up with a particular gauge. You'd have to measure the sensor's resistance or voltage range over some calibrated temperature range or pressure range - it can devolve quickly.
    maine
    Most gauges come with specific sendeing units and are calibrated for the particular sender. If you plan to purchase extra gauges I would check to see if the ports on the sandwhich adapter are npt or bpt and get gauges with the appropriate taper on the sending unit.
