I have been trying for 4 hours to bleed the brakes on this new daytona build. The fronts bled right away. The rears with the 5/8 master will not bleed. Pedal goes right to the floor. I took the master apart and didn’t see anything wrong. I have no leaks. I keep getting bubbles from the calipers. Not just a little. I probably put 2 big bottles of fluid through the system with no luck. I see a lot of bubbles in the reservoir when I pump the pedal. Where is that air coming from? 70 plus cars and have never run into this before.
Any ideas?
Thanks mike
