Results 1 to 8 of 8
Thread: Oil Temperature Sensor Location
    East Hartford, Ct.
    Hi Guys & Gals,
    Does anybody know where an Oil Temperature Sensor can be installed other than the oil pan drain plug?
    Jack
    San Diego Ca 92106
    Feb 2013
    Westminster, MD
    Oil pan is best, Killer B pans have a provision for it.
    Sep 2014
    Is no one using the Oil galley on the block ? there is 2 of them correct ?
    Here was my solution
    http://prosportgauges.com/subaru-oil-galley-plug.aspx
    Saint Charles IL
    Oil galley locations are most common - or a sandwich plate if you have one. Perhaps this would be ideal time for adding an oil cooler. If you do - consider whether you want a thermostat-ed sandwich plate depending on the use of the vehicle.
    Have you considered a oil filter sandwich adapter?
    Is this an option for your engine because it might be if it uses a spin on canister style filter?
    East Hartford, Ct.
    Yes I have. My custom exhaust allows for removal of the oil filter. With that sandwich I would have to remove the exhaust on one engine. I'm going with an M20x1.5 plug with a VDO sensor if I can find one that is ready to go without having to modify it.
    Feb 2014
    The problem with gallery or sandwich adapter oil temp is that the oil has already been conditioned by the factory (or aftermarket) oil cooler and squeezed by the pump. Some senders also will have higher error as pressure is applied. Track guys will typically measure oil temp at a couple of locations, if possible, but ALWAYS at the sump where you see the temp of the oil that is going into the engine.
