0
0
AWIC install and heater coolant bypass hoses
Good evening, I am working on my AWIC install with an EJ207 ver 7. To make the AWIC pipes fit you need to cut down the heater coolant pipes you bypass with a hose, but to cut it down so it will fit you would have to cut below where the pipes goto the throttle body. There are numerous threads out there that detail that all it does is circulate coolant around the throttle body to stop it from freezing up in cold temperatures. Where I live this will not be a problem. The question i have is
1. once you cut it down the pipe will not be rolled at the end, is there a chance that the pipe will work it self out, if so what are my options.
2. the other end of wire the pipe goes to after the throttle body if I cap that off will I run the risk of it blowing off? what would be the correct way to secure the cap.
- You may not post replies
- You may not edit your posts
Forum Rules
