Results 1 to 5 of 5
Thread: Fuel gauge calibration?
    Jacob's Avatar
    Rogers, AR
    I have the vintage gauges from speedhut and the standard issue fuel sending unit from FFR. I don't know the mOhm range of the fuel sending unit. Speedhut mentions that their default needs not calibration. ? Will I need to calibrate the fuel gauge? Added about 4 gals of gas and it registers 1/4 tank so may not need cal?
    MK IV complete Kit - 1st time builder started Sept 2016
    Levy 306
    T5
    2015 Mustang IRS
    Power steering - Levy setup, Breeze roll bars, Thompson trunk box
    fuel injection, powder coating, sway bars, heater, wipers, 17 in wheels
    Quote Originally Posted by Jacob View Post
    I checked my sender before installing it and it is 16-158 Ohms.
    Jacob's Avatar
    Rogers, AR
    thanks, I'll look at the manual but it seems the default range is 16-?, didn't remember the top#
    Levy 306
    T5
    2015 Mustang IRS
    Fairfax Station VA
    The sender provided in my complete kit registered 16 – 160 ohms; no calibration needed.
    MK IV Roadster #8631
    Per the instructions that came with the gauges, 16-158 Ohms is the default setting, so no calibration needed. If you want to verify it, put the gauge into program mode and it should jump up to the 7/8 mark.
