1. What is the shift pattern on the Tremec TKO 600? My clutch isn't hooked up yet and I don't want to start banging through the gears.
2. My FAST EFI setup uses a water temp sensor and that is already installed in the manifold. Since it is wired directly into the harness that plugs into the computer, I assume I will want to run the water temp sensor that came with my gauges separately?
3. What's the best way to test my gauge lighting? I have a Power Probe and assumed if I powered the battery feed and pulled the headlight switch out that I would see the lights come on on the gauges.
