Results 1 to 3 of 3
Thread: alternator and FFR harness?
    what alternator is used with the FFR supplied harness for a MKIII?
    No plug came with the kit and appears to be a one wire set up for the kit? Is the 87-93 mustang alternator a one wire set up?
    If it is a one wire set up, then it has likely been converted to a GM style alternator.
    The attached link may give you some options to consider:
    https://www.summitracing.com/search?...e%20alternator
    Sorry that I can't assist you more; however, I'm a Chevy guy and have converted the stock Ron Francis wiring harness to accept a one wire alternator.
    Personally, I think it is a cleaner looking installation.
    Fairfax Station VA
    If it helps, Forte provided a 1 wire 10SI Delco Alternator 7127-SEN-100A6G, 53170 with my 302. My RF harness (Rev N) came with the plug for a Ford alternator; like Dad I converted it to feed a single wire alternator.
    MK IV Roadster #8631
