Quick technical question.
For the clutch line i had to cut the line short and put in a double flare for it to be the correct length.
I did not have any problems with the factory flares or any of the connections. This connection i made myself is not sealing. The flared bit is not large enough to seat down into the supplied purple adapter. All tightened up brake line just wiggles back and forth because it is not large enough to be clamped in.
This seem like a very noob question but has anyone encountered this?
Thank you
