Results 1 to 3 of 3
Thread: Small Block Chevy Parts For Sale
    Ladies & Gentlemen,
    Here are some parts that will NOT be going in my new Dart SHP Small Block.
    Prior to the engine springing a leak, the car had about 35 miles on it and had received a total of 3 oil changes, not including the final purge.
    No damage was done to any of these parts since only a very small amounts of water (less than a pint) entered the oil system prior to it being discovered.
    Post block leak everything was drained and the block was flushed with fresh oil and filter.
    The engine was then re-primed via an oil pump priming tool which included turning over the engine to purge the lifters.
    Why are these parts for sale?
    I'm upgrading the cam because the new block is designed to accept the later model stock roller set up.
    The oil pan is being replaced because the Dart Block has the dipstick on the opposite side.
    The M77 oil pump is considered to have too much volume for the Dart Block which uses primary oiling so only SBC standard volume standard pressure pumps should be used for wet sump application.
    I've now purchased a Mellings Shark Tooth standard volume, standard pressure SBC pump as suggested by Dart.
    The helical gear design of the Shark Tooth pump reduces the pulsing effect normally associated with a standard straight cut gear 5 tooth pump.
    Milodon Oil Pan #30700
    Will Clear A 3.75 Stoker Crank With H-Beam Style Rods
    $75.00 Plus Shipping
    Comp Cams Xtreme Energy Camshafts #12-250-3
    Includes Lifters & Chrome Molly Push Rods
    (Lifters Were Indexed By Lobe Position Since You Can't Mix & Match After Installation)
    Cam Style: Hydraulic flat tappet
    Basic Operating RPM Range: 2,300-6,500
    Intake Duration at 050 inch Lift: 240
    Exhaust Duration at 050 inch Lift: 246
    Duration at 050 inch Lift: 240 int./246 exh.
    Advertised Intake Duration: 284
    Advertised Exhaust Duration: 296
    Advertised Duration: 284 int./296 exh.
    $125.00 Plus Shipping
    Melling BBC Oil Pump & Pickup #M77
    Standard Pressure / Standard Volume
    The Big Block pump has been used in small block applications for decades and is an old hot rodder practice.
    The 7 tooth pump reduces spark chatter since it reduces the pressure pulsing that is experiences with the 5 tooth SBC #M55 style pump
    $35.00 Plus Shipping
    Last Documented Go-Kart Drive Prior To Block Debocle:
    https://youtu.be/PCngiKoopkA
    Please send me a private message if you have any interest in these parts.
    Bump!
    Update: All items have been sold.
