Do you have to cut out the lower center of the gauge insert so the LS dash fits over the steering column? Or do you lower the column with spacers? All I know is it won't fit. I have telescoping column. Thanks for any help on this.
Steve, I cut it out if I remember correctly , Built Gen 1 in 2007/8.....GTM Twin Peaks.jpg
Yes, I had to cut a part out to fit the steering column (inkluding plastic cover).
GTM #006 (early beta)
On the road in Austria/Europe
LS-7 with Kooks / G50 / Pfadt Bushings
Bilstein shocks, C6 ZO6 brakes with DBA rotors
Lightweight build (2.336 lbs ready to drive)
