Results 1 to 4 of 4
Thread: Where to Get 2006 WRX Control Arm Mounting Bolts
    Jun 2017
    Hello All,
    On or around page 103 of the 818 assembly manual it shows the bolts and nuts for mounting the rear of the control arm to the chassis. Unfortunately, I do not have the bolts or nuts. Anyone know where I can get them. Or even more importantly anyone know the size and grade of those bolts, grade 8, 10, etc?
    Glenn
    Baldwinsville, NY
    I was able to get the bolts at Tractor Supply. I used grade 8. It was too long ago to remember the size. I wanna say they were 12 or 14mm.
    Here is what I used to mount the bushings
    Donor Nut, self locking M14x1.5 4 EA
    Donor Bolt, Hex M14X1.5X50 -10.9 4 EA
    McMaster Washer, M14 - Hardened Flat 8 EA
    Jun 2017
    Thanks for the help. It is greatly appreciated.
    Glenn
