Does anyone know what lower ball joint # is used for a MkII FFR tubular control arm?
Way, way back FFR used a screw in joint in the lowers but your Mk2 should have a press in Fox body lower joint like a Moog K8259.
Thanks Jeff, you are correct. That is what I had thought also. I bought two and measured them up, perfect. Thx. again.
Well jeez guy, give us a part number. My FFR lowers are 6 yrs old so I may need that info. The Moog worked?
Moog K8259 is the correct lower ball joint. They fit the fox body Mustang (1992) and probably others as Jeff has said. I think, have not confirmed it but the uppers should be Moog K772 threaded ball joint. When I get there I will let everybody know.
Thanks!
