Results 1 to 6 of 6
Thread: Ball Joint Help
    Senior Member tonywy's Avatar
    Nanticoke, Pa
    Ball Joint Help
    Does anyone know what lower ball joint # is used for a MkII FFR tubular control arm?
    Way, way back FFR used a screw in joint in the lowers but your Mk2 should have a press in Fox body lower joint like a Moog K8259.
    Nanticoke, Pa
    Thanks Jeff, you are correct. That is what I had thought also. I bought two and measured them up, perfect. Thx. again.
    Well jeez guy, give us a part number. My FFR lowers are 6 yrs old so I may need that info. The Moog worked?
    Nanticoke, Pa
    Moog K8259 is the correct lower ball joint. They fit the fox body Mustang (1992) and probably others as Jeff has said. I think, have not confirmed it but the uppers should be Moog K772 threaded ball joint. When I get there I will let everybody know.
