Probably didn't mess up at all. What happens when you power them up? The temperature and pressure gauges should make a full sweep then return to zero, the fuel gauge should sweep then stop at whatever level is in the tank (assuming it has been calibrated) and the volt gauge should display battery voltage.
Jeff,
What is the best way to apply power to them? I'm gun-shy on the power probe. I have the three power harness leads connected along with my positive batter wire to the starter solenoid with the battery cables disconnected from the battery. I had them connected earlier today and that's when I noticed the gauges with the needles all off the low end of the sweep (including the tack and speedo).
Just put 12 volts to the little red wire in the gauge harness and ground the black wire
Later,
Mk3.1 #7074
