0
0
Lizard Skin and Floor panels
So I just about have the frame and floor pans drilled so I am soon going to be shooting some lizard skin on the floor. I figure that I don't need them to fit tight like the firewall so I should be able to shoot the bottom of the floor pan without having to tape off where the frame sits. Please correct me if i am wrong. Also, I was thinking about spraying the to surface as well. I do have the insulation and sound kit from FFR which would be applied to the Lizard Skin so I don't think it would be an issue.
Also, should I apply the lizard skin to the sheet metal that goes under the fuel tank? Is there much sound from that area once the car is on the road?
