Results 1 to 8 of 8
Thread: 4.6L Headers
    Member JBMorrison's Avatar
    4.6L Headers
    All,
    Looking at ideas for headers for my MkIII build; engine is a 4.6L DOHC (stroked to 5.0L); are 5.0L Coyote headers compatible?
    Happy Thanksgiving!
    JBM
    Feb 2017
    Kansas City, MO
    Happy Thanksgiving! I'm also doing a 4.6 4v in my MkIV. I was lucky and got a pair on new old stock headers from a fellow who bought an uncompleted kit. Prior to that I had found this company who could do a custom set. www.stainlessheaders.com/cobraheaders. Other option, not nearly as sexy is to use stock manifolds reversed and have a custom J-pipe made from an exhaust shop.
  3. Likes RSCamaro liked this post
    The mounting flanges and stud footprint to the heads are the same then between the 4.6L DOHC and the Coyote?
    JBM
    Feb 2017
    Kansas City, MO
    I don't see how they could be the same. The block of the Coyote is a fraction of an inch longer, so the heads would need to accommodate that difference.
    Senior Member 3yearplan's Avatar
    Dearborn Heights, MI
    Do you guys NEED the J-pipe? Can't you use the FF 4.6 DOHC headers?
    Mark IV 7923 arrived 11-14-12
    DOHC 4.6L, Tremec 3650, 3 Link 8.8 w/3.73
    Quote Originally Posted by 3yearplan View Post
    I’m looking for a header with the O2 sensor bung in the collector to use on the 4.6L DOHC.
    JBM
    Feb 2017
    Kansas City, MO
    The FF 4.6 header was discontinued. I was not able to find an ongoing provider of new mass produced 4.6 4v Headers for a Cobra, only custom headers. Stock exhaust manifolds with J-pipes would be the lowest cost options.oh
  9. #8
    I understand. I just ended up welding the bung into the collector portion of the side pipe. I also did not know the FF 4.6 headers were no longer available.
