Take a look at the photo (please). Pretty standard stuff for most other than yours truly. Here's today's challenge: I have three red wires (RF Harness), a "battery" cable (it's actually coming from the master cut off, prior to the 250a fuse) and the Coyote starter cable off the PCM.
I have three posts on the starter solenoid. The documentation is fuzzy enough that I'd like some verification/correction on what goes where. That's where you come in! The RF manual shows a black cable going to the bottom right (looking from the front of the car). Black - must be a ground, yes? Then the four red cables (three from the RF Harness and one from the battery) go to the outboard, or bottom left post, and the coyote cable goes to the top post? Or will everything go boom if I do it that way?
