Thread: Wagon LCA not lining up?
    wagon donor, I'm supposed to use the outer holes. The front mount....
    But then the rear mount wants to pull in to the inner hole.
    Do I pry this thing over?
    FYI this is the passenger side, same issue on the driver side.
    Senior Member EODTech87's Avatar
    Feb 2013
    Copperas Cove, Texas
    It's just the mounting points not being perfectly square or straight. I remember having to man handle the front control arms into the correct holes as well.
    -Jason
    Thanks. I'll go handle them like a man.
    This was my picture 4 years ago with wagon LCA..
    I had to modify the holes.
    San Diego Ca 92106
    Quote Originally Posted by turbomacncheese View Post
    Lol , triggered some funny pictures in my head.
    Thanks Bob. I figured it had to do with how the brackets were set up, but I wanted to check before I bolted them up. I expected this project to challenge my skills, and it is. I've found it has also challenged some of the things I thought I knew. Not going to take a chance on something I know I don't know, especially when it's so easy to get help here.
    That's my goal!!
