Has anyone put the AC pedals over the stock type pedals, if so how did you bond them to the metal on the pedals?
Both Forte (http://www.fortesparts.com/factory-f...ood-pedal-pads) and ********** (http://www.**********accessories.com...edal-pads.aspx) have bolt on pedals. I'd call Forte and tell him what you need; he's extraordinarily knowledgeable, competitively priced, and his customer service can't be beat.
MK IV Roadster #8631
Later,
Mk3.1 #7074
has anyone just ground off the mount on pedal and used a bonding agent to attach them?
I cut (+ ground) off the mount on the pedal and used 4 small flat head Allen screws on each.
I picked a (black) screw head that would countersink in the (black) lines of the AC pedal - in the lines above and below the AC emblem.
Drilled through original SN95 pedals to attach.
Works great.
IIRC, I had to rearrange the angle of the brake pedal, which got a significant rework for manual brakes anyway (6:1 / length mod).
One nice feature of how I installed mine is that they rotate through the pedal travel - keeping them flat on my foot without over-articulating my ankles. I spring-loaded them, too, so they don't flop down or rattle when at rest.
Later,
Mk3.1 #7074
I cut the old pedals off, put the pedal arms on a vice and bent them to the right angle, drilled a hole in pedal arms that matched the AC pedal holes and bolted them together.
