Results 1 to 8 of 8
Thread: AC pedals
    Jul 2014
    colorado springs co.
    AC pedals
    Has anyone put the AC pedals over the stock type pedals, if so how did you bond them to the metal on the pedals?
    Fairfax Station VA
    Both Forte (http://www.fortesparts.com/factory-f...ood-pedal-pads) and ********** (http://www.**********accessories.com...edal-pads.aspx) have bolt on pedals. I'd call Forte and tell him what you need; he's extraordinarily knowledgeable, competitively priced, and his customer service can't be beat.
    MK IV Roadster #8631
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    I cut off the original pedal pads from the donor brake/clutch combo and welded on a couple of tabs, to which I mounted the AC pedals.
    I also notched the brake lever so that the AC pedal would have room to articulate....
    Later,
    Mk3.1 #7074
    Jul 2014
    has anyone just ground off the mount on pedal and used a bonding agent to attach them?
    Quote Originally Posted by feadam View Post
    I cut (+ ground) off the mount on the pedal and used 4 small flat head Allen screws on each.
    I picked a (black) screw head that would countersink in the (black) lines of the AC pedal - in the lines above and below the AC emblem.
    Drilled through original SN95 pedals to attach.
    Works great.
    IIRC, I had to rearrange the angle of the brake pedal, which got a significant rework for manual brakes anyway (6:1 / length mod).
    One nice feature of how I installed mine is that they rotate through the pedal travel - keeping them flat on my foot without over-articulating my ankles. I spring-loaded them, too, so they don't flop down or rattle when at rest.
    Later,
    Mk3.1 #7074
    Afterthought - I may have rearranged the angle on the clutch pedal too.
    One of the beauties of the SN95 pedal box is that they are steel and (relatively) easily reworked to how + where you want them to fit in the foot box.
    minnetonka,MN
    I cut the old pedals off, put the pedal arms on a vice and bent them to the right angle, drilled a hole in pedal arms that matched the AC pedal holes and bolted them together.
