Results 1 to 13 of 13
Thread: Heat Shield
    Nov 2016
    Heat Shield
    I'm looking into what heat/sound barrier I want to use inside the cockpit. Does anyone have any recommendations (PN's would be helpful also)? Just looking at Summit's site, I'd maybe go with Dynamat 11101 or Thermo-tec 14620 (for a self adhesive type). I know I need to keep it thinner to avoid eating up space, but how low can you go? What's worked well for everyone?
    Thanks!
    Ben
    Nov 2016
    Oh, and how about EZ Cool's product?
    Jax Beach, FL
    I used EZCool. It is a thermal barrier. The really nice thing is that it is lightweight. It is not self-adhesive, but very easy to install.
    From EZCool:
    Q: How thick is this insulation?
    A: This insulation is approximately 3/16" thick.
    Q: What is the R Value?
    A: Down = 13 Horizontal = 9.6 Up = 8.1 This is better than 2" of fiberglass insulation.
    Dynamat 11101 looks pretty thin(1/8") to me. I would go up to a thicker one if I went that way. The sound deadening properties are pretty much a waste on a car with the exhaust 2 ft below your ear. It is also single layer, so will likely not be that great of a thermal barrier. Also, from their web site "For best results, install Dynaliner over Dynamat." So it looks like it is designed to be an add-on product.
    Oh. For most of us, we have only ever used one product. So not a lot of us can give you a comparison. There might be a couple guys out there that have tried different products.
    Senior Member Jdav's Avatar
    ATL GA
    I used the Thermo-tec product that you noted and was happy with it.
    I would definitely recommend applying it to the footbox prior to putting in your pedal box.
    MK4 #9028 - Coyote - TKO600
    Aug 2017
    Southern WV
    I used hushmat from summit on all the aluminum panels to help with the drum sound
    With that and carpet the heat is not to bad I found that a lot of heat came in around the front fenders at the door hinges if the seal leaked
    I agree that it doesn’t make much difference with the sound levels with the wind, road and exhaust noise and wearing ear plugs I cannot hear the horn above 60 mph
    Rick
    Leesburg, Va
    I used Dynamat. Easy to install. It does help with the heat fron the engine, but at speed it is the wind and exhaust noise are the issue. I wear earplugs all the time.
    Doug
    FFR 7995
    Mark Eaton's Avatar
    Medford, Oregon
    I'm planning on using Lizard Skin
    Vote #2 for Thermo-Tec. It is easy to cut and apply, it works great, You can buy it on Amazon, and it is cheaper than others. I put it everywhere. It really makes the cockpit sound solid. I even put it inside strategic parts of the body that you can't see to make it sound more solid.
    Another satisfied thermo-tec customer here.
    Also second the above recommendation to apply it to the inside of the footbox panels before installing them.
    Senior Member jlfernan's Avatar
    Port Orange, Fl
    EZ COOL INSULATION http://www.lobucrod.com/
    This stuff works great. Light, cheap, and easy to work with.
    Senior Member Lowrod's Avatar
    Nov 2015
    Mount Olive AL.
    What is the average Square Footage needed to insolate a Roadsters interior?
    Port Orange, Fl
    About 40 sq ft for just the interior, more if you're doing the trunk.
    Jupiter, FL
    Quote Originally Posted by jlfernan View Post
    How thick is this stuff? Do you need to glue it or is there a sticky back already?
    My main concern is heat...would this help?
    Martin
