Results 1 to 3 of 3
Thread: Front oil cooler size.
    Senior Member fact5racer's Avatar
    Anybody know the ideal oil cooler size for the lower front opening? Brand?
    Senior Member Todd Baumann's Avatar
    Howell Michigan
    This is the one that fits and is identical one to what FFR used to sell except for the fittings size now.
    Earl's Performance Temp-A-Cure Fluid Coolers 81300ERL
    Earl's Performance AN to Straight Cut O-Ring Fittings 585108ERL
    HTH
    Todd
    Todd Baumann
    FFR Build School Instructor 16+ Years Mott Community College
    FFR 2086 MKI, 22+ years on the road
    FFR 300 MKI Coupe
    Mar 2013
    Medway, MA
    The Breeze oil cooler is 3.75" tall (13 rows) and 11.25 wide plus the length of the side wings.
    https://www.breezeautomotive.com/sho...ake-off-plate/
    By the way it is a Mocal and made in the original factory in England same as the originals I am told.
    This is sized for the Roadster so you don't need spacers to hold the cooler down below the lower radiator aluminum. I think the original size is shorter on the 289 and if that is your applicatoin Breeze can also supply a 10 row cooler which is about 3" tall or a 7 row which is about 2" tall.
