Results 1 to 5 of 5
Thread: Vinyl Cockpit Rear Wall
    Feb 2017
    Looking for photos of rear cockpit walls with vinyl instead of the carpet. Details on how it was installed, where were seams, where were breaks between vinyl and carpet, etc.
    Tried the usual suspects for build threads with no luck - but I sure assume there are some out there.
    Greg
    Frankfort, IL
    Not directly on point and photographing black is nearly impossible, but if i recall correctly, the Roadster has a similar vertical/horizontal break on the back wall at some point. On the 818, I ran Vinyl on the upper portion until the first hard break. The thickness of the carpet made it easy to run up against each other at an inside corner. If I were to do it again, I would probably run the vinyl down even further for a more OEM/production look (you rarely see carpet on vertical surfaces higher than your knees in a production car).
    JDAV did vinyl on his. Check his build thread.
    Feb 2017
    Perfect - exactly what I was looking for. Thanks Scott. Thanks JDAV...... (Does look nice!)
    Senior Member Jdav's Avatar
    ATL GA
    Quote Originally Posted by frd2 View Post
    Thanks. I love the way it turned out. Let me know if you have any questions beyond what I noted in my thread
    MK4 #9028 - Coyote - TKO600
