Results 1 to 7 of 7
Thread: HELP!! Just got unfinished project for GTM supercar
    Dec 2017
    Hi all.. im Kris from Indonesia.. i just bought GTM supercar gen I from my friend.. but he was die..
    I dont understand to build this car and what parts left to build completely..
    Now im going to move the pedals and steering side from left to rhd..
    I didnt get the steering column.. does anyone ever use aftermarket or universal steering column that fit to this car and fit for the electrical switch?
    Theres so many parts to buy.. i just get the chassis, body, and engine.. (here i cant upload the pic.. dont know how to upload)..
    For now i need parts like :
    Steering column
    All glasses
    Power window
    Power steering (should i use power steering? Front wheight is light enough if no power steering)
    It seems lost for the fork transmission parts
    The engine type is LS 1 with 12559378 casting code..
    Senior Member beeman's Avatar
    Indiana
    GTM #304 LPE 525hp LS3
    Dec 2017
    I just bought the manual.. but it doesnt explain for other option.. only from c5 corvette donor parts..
    Have u ever use aftermarket / universal parts for the steering column?
    Banned
    Aug 2011
    I'd use the c5 corvette steering column if you can get one. You could use another steering column but you'd have to make the mounts and figure out the connection to the steering rack.
    My best suggestion is to read a lot of the threads/posts on this forum. read through manual and educate yourself on this car before jumping into this build. You should have all the glass with the kit. might be a good idea to go though all the parts to ensure you have everything that comes with the kit, then work on the list of donor parts you need.
    Team Bouffard
    GenII #369 - SOLD
    1968 Camaro - work in progress
    Kris,
    I updated your account so you can edit your profile and upload pictures to the gallery.
    Check out this thread for tips on how to embed pictures:
    http://thefactoryfiveforum.com/showt...tures-in-posts
    Indiana
    Here's how I used an EPS unit, was easy to tie into the rack.
    http://thefactoryfiveforum.com/showt...l=1#post267596
