Results 1 to 11 of 11
Thread: engine won't start w/ pcv connected
    Jan 2016
    I hope everyone here is doing well, i'm at the very end of my build and have an appointment w/ the DMV on December 8th, I went yesterday to my local autozone and got a PCV valve for the car. I installed the pcv valve on the passenger side valve cover to the the 3/8" nipple at the back of the carburetor and on the driver side valve cover i connected it to the air filter. Now my car won't start with the pcv connected, once i disconnect it, it runs just fine and everything is good but the moment i reconnect the pcv valve to it, it shuts down. I tried readjusting the idle mixture screws but still nothing. any advice? Idk much about carburetors but i''m trying to do everything I can. Thank you
    Windsor, CT
    When the engine runs, is the PCV port on the carb blocked off or wide open?
    Jan 2016
    When the engine starts the pcv port is wide open
    Southern WV
    Sounds to me that you may need to turn the idle adjustment to open the throttle and let the motor have a little bit more air at idle
    The motor should run with or without the pvc port being open it will run rougher with the pvc port open and no pvc value because of the vacuum leak
    Rick
    Jan 2016
    Quote Originally Posted by Itchief View Post
    Rick
    You’re absolutely correct! I had the idle adjustment done incorrectly since my pcv port was open and it was seeing a massive vacuum leak. I ended up plugging that port and readjusting everything and it fired right up and now I’m adjusting the idle mixture with a vacuum gauge to get it running good, thank you very much!
    Southern WV
    Your welcome
    Member JRD56's Avatar
    Oct 2014
    Olathe, KS
    I installed an adjustable PCV on my car. (302 w/carburetor). I bought one from ME Wagner. There is a couple of good articles on their website about the challenges of selecting PCV valves for non-OEM engines, like ours. http://mewagner.com/
    Quote Originally Posted by JRD56 View Post
    Very Cool & Makes Perfect Sense!
    Didn't Know These Even Existed!
    Thanks For Sharing!
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    The 3/8" port at the bottom rear of the carburetor is for vacuum for power brakes. Using it for PCV is, as mentioned, a massive vacuum leak.
    Later,
    Mk3.1 #7074
    Oct 2014
    Olathe, KS
    I'm using the 3/8" port on the rear of my Quick Fuel for the PCV valve with no issues. The instructions for QF make reference to as a use for either power steering or PCV valve. If using it for a PCV valve and the engine does not run properly then there is likely a problem with the PCV valve. PCV valves can be tricky, refer to the articles above. I own several vintage mustang with this arrangement from the factory.
    Southern WV
    If you installed a tee you could use the 3/8 port for both a brake booster and a pcv
    Rick
