Results 1 to 3 of 3
Thread: GT40 heads / stock gaskets ?
    NY
    Swapping the heads on my 89 mustang 302 , can I use the stock gaskets from the old heads, they are new
    Northern VA
    I could be wrong so verify this. The head gasket should fit, but I believe the thicknesses for e7 and gt40 gaskets are different. Obviously changing this thickness will change your compression
    If the gaskets were installed and the head bolts torqued I trash them.
