Results 1 to 6 of 6
Thread: Teardrop area under the trunk?
    Jacob's Avatar
    Rogers, AR
    Do most builders fabricate their aluminum cover over the teardrop shaped area under the trunk? Or do one of the vendors have this item?
    Levy 306
    T5
    2015 Mustang IRS
    Senior Member jlfernan's Avatar
    Port Orange, Fl
    Made my own.Bought a piece of aluminum sheet 6"X12" at Home Depot, some tracing pager and thirty minutes later, it was done.
    Chino Valley, Arizona
    Ditto - made my own, pretty easy & don't believe any vendor sells them.
    Dark Water used to sell them. But after buying one (back when he was selling things regularly) and finding it was just a flat piece of aluminum that I had to bend, just made them myself. Probably one of the easiest to fab parts on the build. Make a pattern from Kraft paper (or whatever) by holding over the opening and tracing. Cut out the part, drill a few holes, bend, you're done. I hold it in with nut plates glued inside the lid and button head screws. The same ones I use on the hood scoop. You could use self-tapping screws if you want. I just prefer machine screws because there isn't a lot of glass to bite into there. Have it loose and painted at the same time as the body, and it will blend it and look nice and finished.
    Lost Wages, Nevada
    Wait . . . we're supposed to cover that hole???
    Just kidding.
    Doc
    Jacob's Avatar
    Rogers, AR
    Thanks all...just the info I needed. Actually did it this afternoon and it did take all of about 45 mins!
    Levy 306
    T5
    2015 Mustang IRS
