Thread: Timing Light hookup
    Senior Member jwebb's Avatar
    Longmeadow, MA
    Timing Light hookup
    Being my battery is in the trunk, I can hook the light up to a separate 12 volt source, correct? Light doesn't long enough leads
    Senior Member canuck1's Avatar
    Victoria, BC CANADA
    Yes. Any constant 12v source will do.
    Sean
    MK 3.5 roadster (MK IV body retrofit to MK III chassis) 396W stroker, 4 bbl mass air EFI, QH (self-tuned), AFR 195CC Renegade, XE274HR, GP 4-1-4 SS headers, 3link, 3.73, 15" Halibrand replicas, SAI mod, bumpers, 2 X roll bars, IČ electronics, PS, hydroboosted brakes: 95 GT front, custom MK VIII calipers/Cobra discs rear, FFR front, Levy rear LCA's, Forte front, VPM rear bars, CF dash, mod comp layout w/Auto Meter Ultra-Lites, Lucas tri-bar headlights, coupe taillights, painted by SRP (again!)
    Seasoned Citizen NAZ's Avatar
    I have a one-wire alternator that is connected directly to the positive terminal on the battery (the battery is mounted in the rear). I hook my timing light positive lead to the output terminal on the alternator and the negative lead to a good ground.
    Longmeadow, MA
    Thanks!
    I just hook the hot lead for my timing light up to alternator output.
    Northern VA
    same here
    Vermilion,OH
    Or a positive terminal block, or on the batt side of a solenoid. But a separate batt works too.
