Results 1 to 31 of 31
Thread: Cadillac rear caliper mounts
    Nepa
    i had a set of rear brake caliper mounts made to use the same set up on the rear as my front. hes going to make 10 more sets. if anybody would be interested price is unknown until he gets back to me in a few days. i can text pics if interested pm me number and i can send them. will become supporting vendor if theres interest in them thanks
    2013-2015 ATS Brembo calipers
    2004-2007 Cadillac CTS-V brake pads
    2004-2007 Cadillac CTS-V Caliper pin kit
    2004 STI 5x100 front rotors
    San Diego Ca 92106
    Any word on prices yet? I'm on The fence about upgrading at this point. I'd have to convince the CFO to justify this upgrade.
    Quote Originally Posted by Samiam1017 View Post
    I'm interested for my second car.
    Atlanta, GA
    So you're using the ATS (non-V) front 4-piston Brembos on the rear of your 818? How are you doing the parking brake?
    Portland, OR
    What size wheel do you need to fit these calipers? Will a 17" wheel clear or would it have to be an 18?
    San Diego Ca 92106
    Here's a link that has the Cadillac brake discussion. http://thefactoryfiveforum.com/showt...upgrades/page2.
    Syracuse, NY
    MK3.1 Roadster completed 2011
    Nepa
    Quote Originally Posted by lsfourwheeler View Post
    im using a hydraulic line lock
    Nepa
    Quote Originally Posted by autostang View Post
    i have 17in fronts and they clear but im using 18in rears
    Nepa
    i will know pricing thursday night im haveing a 10 pair run prices out to start
    Nepa
    where i am at on my brakes
    willwood pedals
    4 sti rotors cheaper street rotors
    4 Cadillac calipers
    4 pr street pads
    retaining clips for pads
    cadillac swap front caliper mount kit
    im at around 1400 total
    i didnt pay for rear mounts or masters for the pedal assembly
    Nepa
    if somebody would like to post pics for me i can text them 57085240 three four thx
    I'm posting these 2 picture for Samiam1017
    Nepa
    thanks bob
    Nepa
    A pair will be $195 shipped in the continental usa will include two caliper adapter plates, hardware to mount caliper to mount , hardware to mount bracket to your bare hub.
    thats based a a 10 pair run at a time. if your interested on a set lmk thanks. if it looks like 10 sets will go i will register as a vendor also thanks
    Nepa
    i have 4 sets available if anybody is interested message me thanks
    Huntsville, Al
    PM sent
    Charm City
    Just courteous to know what the bolt spacing is for the caliper mount holes C to C? If it’s a common say 5-1/4” they would also work with various calipers from a vendor like Wilwood.
    FFR 818r Instagram biknman69
    • Ernest Hemingway
    Nepa
    biknman i will have to get a measurement tomorrow for you as im not at the shop tonight.
    erik ill message you tomorrow night also as all the kits are at the shop also thanks
    Nepa
    one set left if anybody is interested he has enough material to make 4 more sets if theres a demand thanks
    Jul 2014
    Strathroy, Ontario Canada
    will these brackets fit the stock 2004 WRX Wagon (non STI) rear hubs? I know I need new rotors but between rotors and cadillac calipers this will all work? also is the parking brake not in the inside side of the rotor with 2 small shoes. it should be separate from the caliper. I am very interested in this.
    Jul 2014
    sorry did not read the origional post properly to see you were using front rotors on the rear.
    wondering about the spacing as well... trying to put together a rear brake kit that doesnt use the factory ebrake... thanks!
    Williamsburg VA
    This is my setup with the brackets. I have 2002 Wrx spindles with no parking brake. I am using a drift handle to apply the rear brakes like a parking brake. I had to add a 5mm spacer to keep the wheels from rubbing the calipers.
    Thank you for that... can you measure the caliper bolt spacing? id like to cut these down like the p&l brackets so I can install without doing the bearings... again.
    Saline, Mi
    Quote Originally Posted by taco20 View Post
    Can you explain how a drift handle helps you have a parking brake when you just have calipers w/o internal drums? Thanks
    Williamsburg VA
    Quote Originally Posted by frankc5r View Post
    I have the rear brake line going into the drift handle/parking brake. It applies both the rear calipers and has a lever to hold the handle up thus acting like a parking brake. Some states might not like the parking brake not being separate but I track my car more then anything so no big deal to me.
    Saline, Mi
    Thanks for reply
    Senior Member Junty's Avatar
    Dec 2013
    New Zealand
    Similar to taco20 - Im installing the same concept - except mine has dual hydraulic handbrake (drift brake with bracket) so that i can retain Subaru ABS.
    Dec 2013
    New Zealand
    Hey - checking for some help here... Ive installed Samian's rear brake caliper mounts along with new AVS (brembo callipers). Ive used 326 x 30 Brembo rotors. However my callipers are mounted too far from the centre of the hub? The could be moved inward at least 10mm - the outside 10-12mm of brake pad is not in contact with the rotor and the centre of the rotor is not contacting with the pads either?
    Super Moderator
    Ray's Avatar
    La Mesa, California
    I know that it’s tough to start a parts business and that you’re trying to help other builders with what looks like a really good product, but, you are going to have to become a registered vendor if you wish to continue with sales of these brackets (or any other parts/service.)
    It’s been approximately 9-months since you first posted this topic (and mentioned that you would become a vendor) so I’m going to ask that you do so.
    This thread will be locked and any further similar topics will be deleted until the vendor registration is completed. If you have any questions please contact me or any of the other Moderators/Admin staff.
    Ray
