Thread: Parking brake parts
    May 2016
    Parking brake parts
    I have sn95 11.65 brakes and cables from the complete kit for a mustang handle. What kind of retaining clips do I need for these cables in the caliper as well as the frame tunnel mounts in the other end of the cable aft of the handle?
    May 2016
    Maybe I am asking the wrong question since 50 people passed on a reply. what did you use from calipers to the brake handle from a fox mustang?
    Junior Member mtcoriel's Avatar
    21035 S. Ron Lee Dr. Shorewood,Il 60404
    1994-04 Mustang Rear Park Brake Cable E-Clips
    May 2016
    Thanks. My cables are so long they reach the brake. Do I need the factory five handle or do I need to modify cables to work with the donor handle
    May 2016
    I need the clips for the cables the connect to the frame. Are these available anywhere else?
    [IMG]4d7af2_f8ee72dc2f094115a3a569a1fb6857cd.jpg_256[/IMG]
    May 2016
    I need the clips for the cables the connect to the frame. Are these available anywhere else?main.jpg
    Mar 2013
    Medway, MA
    There is no clip where the jacket mounts to the frame - just the barbs snapping into a hole.
    These are the clips at the caliper: http://www.breezeautomotive.com/details.php?prod_id=403
    They are not really necessary as the cable jacket becomes captured once the assembly is installed.
    They are known as 10mm e-clips.
    So really the only thing you need to do is cut off the front cable mount and re-attach (weld) it in a fashion that the cables have a fair lead out of their jackets and the splitter cable http://www.breezeautomotive.com/details.php?prod_id=181 has a fair lead onto the parking brake handle pulley.
    On the other hand if you would prefer to leave all that and those parts off your car you can install a hydraulic parking brake valve like this in the driver side floor just in front of the seat: http://www.breezeautomotive.com/deta...p?prod_id=1000
    Hope that helps!
    May 2016
    Thanks Mark. My cables don't have barbs to retain them into the chassis. Can't find replacements but may not matter if I use the adjustable setup from lokar. Thx.
