Pegasus PRI Show Special on Pedals
PRI 2017 Specials
Free master cylinders and remote bias adjuster cable!
For a limited time, purchase a selected OBP Track-Pro pedal box (BMW E36 LHD, BMW E46 LHD, or Subaru Impreza LHD) at the regular price and receive three OBP master cylinders and an OBP remote bias adjuster cable free!
There is no limit to the number of pedal boxes you can order (one set of 3 masters and one cable per set), but hurry -- this offer expires when the clock strikes midnight on New Year's!
This item qualifies for FREE Shipping in the continental United States!
Receive Master Cylinders and Remote Bias Adjuster ($170 value) with the purchase of select Track Pro Pedal Boxes! For a limited time, receive 3 OBP master cylinders and an OBP remote bias adjuster cable when you buy the OBP Track-Pro pedal box at regular price.
This 3-pedal floor-mount pedal box offers an all-in-one system that is designed just for the Subaru Impreza. The lightweight steel Track-Pro assembly includes Clutch, Brake, and Throttle pedals in one unit.
All three pedals ride on oil-impregnated bushings for smooth, consistent operation and long life. The master cylinders (included) are positioned under the driver's feet for the easiest and most compact installation. Just install your masters, bolt the assembly to the floorpan, and hook up the hydraulics and the throttle. No cutting or welding required! The 5.5:1 pedal ratio is ideal for road racing and rallying.
Clutch pedal: For hydraulic clutch. Includes a built-in adjustable pedal stop to prevent overtravel.
Brake pedal: For dual master cylinders. Includes a built-in bias bar.
Throttle pedal: Designed to be easily adapted to the Subaru cable. Spring-loaded with an adjustable return stop.
The Clutch and Brake pedals have traction tape pre-applied. The Throttle pedal pad is perforated for comfort. PRI Special: Includes 3 master cylinders (5/8" front, .70" rear, and .75" clutch) and a remote bias adjuster cable. Weighs approximately 7 lbs with master cylinders. Remote fluid reservoirs and fittings sold separately.
Add the Master Cylinder Cover Plate (Part No. 3537-301, sold separately) to protect the master cylinders and give a finished appearance -- and to provide the driver with a footrest.
https://www.pegasusautoracing.com/pr...sp?RecID=28192
Owner: Colonel Red Racing
eBAy Store:
http://stores.ebay.com/colonelredracing
818R ICSCC SPM
