Thread: Brake Line
    Senior Member jwebb's Avatar
    Longmeadow, MA
    Brake Line
    After installing the headers on drivers side noticed tight fit with the rear brake line. Hasn't damaged the cushion on the clamp yet but could this be a problem? Should/could I just put a layer of heat shield over the brake line?
    slpro1207's Avatar
    Moorpark, CA
    I’m no expert but that looks to close to be safe over time. I don’t know if I would trust that even with a heat shield that you might get into that tight a space. IMHO.
    MK4 delivered 2/24/2017. Complete kit #9023,IRS, Power Steering, Leather, heater, 17" wheels, sway bar ft & rr, tremec 600 and Gordon Levy Racing SBF 427. First start and go kart 8/19/2017. Graduated 1/15/2018
    MK4 #9230 complete kit delivered 1/27/2018. IRS, PS, leather, Tremic 600, SBF 427. Graduation 10/15/2018
    MK3 #5253 donor bought unfinished. SBF 331, T5 Trans.
    Senior Member MPTech's Avatar
    St. Louis, MO
    I think that will be a serious heat problem. I know it's not desirable now, but if it was mine, I'd move it to the other side of the DS FB.
    Seasoned Citizen NAZ's Avatar
    Too close for any effective heat insulation.
    I agree, too close to a heat source. The last thing you want is to be heating your brake fluid.
    Agreed. I'd move the line.
    Longmeadow, MA
    Move the line it is, thanks!
