Results 1 to 4 of 4
Thread: Heat cycling question
    Good morning, if someone could be so kind as to run me through the procedure they did to heat cycle their 818, thank you
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    did you do the cooling system mod? Which motor?
    yes did the cooling system mod, EJ207 ver 7
    San Diego Ca 92106
    Putting this link in so I can find it later. So much good info gets buried in build threads .
    https://thefactoryfiveforum.com/show...640#post322640
    Pg 9. Starting with post 332
