Thread: power seat
    Nov 2016
    Mi.
    power seat
    Has anyone installed a power seat in a 33 ? If so what will fit?
    I doubt it. The cockpit is very tight in the seat area.
    Placitas, NM
    Speaking of seats can the seat bottom/back be easily removed to add heating elements inside them?
    Oct 2014
    Vermilion, OH
    Jim, I put them in my Hot Rod seats and its very easy. The bottom cover is just glued on, remove the cover, install the heater and use trim adhesive to reinstall the cover. I didn't remove the seat back cover to install the heater, I pulled the long plastic clip (the same style that holds the seat bottom to the frame) and pulled the cover away from the cushion to install the heater. Once you start its pretty easy.
    CVOBill
    Placitas, NM
    CVOBill, thanks for the info.
