Results 1 to 8 of 8
Thread: Fuel Pick-up (Returnless System)
    Senior Member mach'er's Avatar
    Monroe, MI
    I am doing a returnless fuel system. The fuel pick-up has a little orange cap on the end of the return line, which the instruction manual says to take off.
    I installed my tank already, and put the pick-up in with the little orange cap still on there (sort of like this picture from the manual), since I'm not using the return line.
    I'm now having second thoughts, and think I'm going to take the pick-up back out of the tank, remove the little orange cap, and then cap off the return line externally.
    Does any of this really matter? Why take the little orange cap off if you're not running a return line? My only thought for why it would matter is that the little orange cap could fall off and you'd never know it.
    Thanks. (And yes, my build thread is a little bit behind my actual build status).
    --Curt
    Roadster #9146. Complete Kit, 363 w/Jim Inglese Weber Carbs, Forte TKO600 w/Hydraulic Clutch, IRS, Wilwood Brakes, F & R Sway Bars, 17" Halibrands, Power Steering, Breeze Front Battery Kit, Herb's Door Panels, and who knows what else left to be added.
    Ordered 5/19/17. Delivered 8/18/17. Slowly Building.
    Unconventional Builder Joee's Avatar
    Hatboro PA
    Do you have an additional breather opening on the tank?
    Roadster Mk3 5294, 302 Comp XE276HR cam, AFR 185 heads, 650 Quick fuel carb, Air Gap intake, T-5 3.55 gear Levy Upper & Lower Front and Rear control arms Purch Jan 2008 Tagged Mar 2012 Best ET 12.14 @113** SOLD 4/8/18 **
    YouTube Videos: Current performance - https://www.youtube.com/channel/UC7c...86xO3U4l4RtVMQ Older build - http://www.youtube.com/user/joeembery#p/u My Pics:
    http://s207.photobucket.com/user/Joe...?sort=6&page=1
    Monroe, MI
    Yeah, the normal tank vent. Which I’m still trying to figure out the best routing/location for...
    Senior Member jwebb's Avatar
    Longmeadow, MA
    I left the cap on and haven't had any issues yet...
    Feb 2017
    Moose Jaw, Saskatchewan, Canada
    I have always wondered what that little orange cap is for?
    Quote Originally Posted by kcorn View Post
    I'm thinking they were aimed to spray return fuel on the pump housing.
    A side benefit of the return system is the return fuel is (most) always overfilling the baffle.
    Ohio
    You could also think about purchasing the single fuel pickup from Breeze. Same diameter tube as FFR. I also was concerned about the cap falling off so bit the bullet and called Mark. Good luck.
    JRL16
    Hatboro PA
    Quote Originally Posted by mach'er View Post
    Start here this has been covered a lot in FFCARS.COM
    http://www.ffcars.com/forums/17-fact...tank-vent.html
