Results 1 to 6 of 6
Thread: Neutral and reverse switches
    Edmonton, Alberta
    I can’t seem to figure out how these switches work. They seem to be identical, a simple 2 wire plunger that I figured would either have continuity when depressed or extended. However I have 4 of them, and can’t get any of them to “activate”. I was going to use the neutral switch to prevent starting in gear, but I can use the clutch switch to accomplish the same thing. But the reverse switch is needed for the backup lights. Any help would be appreciated.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    Syracuse, NY
    I had the same issue. Turned out the switches were bad. The wires break inside the insulation right were they enter the plunger as they get twisted and crushed when installing/removing. I just bought two new ones and now the neutral and reverse switches work correctly.
    If you want to sacrifice one to test, you can cut the wires off close to the epoxy were they enter the switch. Then use you multi-meter to test for continuity when pressed and not pressed.
    MK3.1 Roadster completed 2011
    Edmonton, Alberta
    Thanks, I’ll pick up a new one and test it.
    818 SRX - #91
    Arrived 01/02/2014
    Edmonton, Alberta
    Picked up a new one today and it works perfectly, can’t believe all 4 of mine were bad. I was under the impression that the rearward one (both on d/s of t-case) was the reverse and the forward one was neutral. However they both appear to only have continuity when in reverse, so perhaps it’s a redundant system? Either way I can solve my not starting in gear issue with the clutch switch. Thanks again Hobby Racer!
    818 SRX - #91
    Arrived 01/02/2014
    Saline, Mi
    Both of mine on my 5 spd were bad too.
    Must be a crappy design. Need one for
    backup lights. Probably order one.
    Banned
    I've had three go bad, and my current reverse one is on the fritz. I'd highly discourage relying on one as part of your starting circuit.
