Results 1 to 9 of 9
Thread: High/low beam toggle
    Jun 2017
    The only toggle I have left that has 2 positions for high and low beam...has 6 small pins(2-rows of 3). My wiring harness has only 3 wires (high beam, low beam, switch) and they have large spade connectors.
    I could split and put 2 connectors on each wire or should I have received a 3 spade 2 position toggle from FFR????
    Thanks!
    Northern VA
    I could be wrong, because I did the base kit. But you need a 2 position 3 spade. It is a Single Throw Double Pole switch. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Jul 2017
    that's the switch for the hazard flashers
    Perhaps they don't provide a switch for the high/low? Some builders use the more traditional foot switch for that purpose. That switch might be for hazard lights?
    Northern VA
    the six prong switch is for the flashers. If using the RF harness, you will have 4 wires going to it.
    Quote Originally Posted by brrgy View Post
    Thanks!
    From left to right: turn signal, hi/lo beam, hazard flasher
    By the way, I ended up using a floor mounted hi/lo beam switch - details in my build thread.
    Chino Valley, Arizona
    Quote Originally Posted by alv69 View Post
    Correct, I have an early MK4 basic kit and purchased the RF wiring kit from FFR and that switch is for the hazards.
    Lost Wages, Nevada
    IF that's the only switch you have left, you can use it (or get another 3 prong type), just wire one side only.
    Doc
    Jun 2017
    Thanks for the responses guys!!!
    I was shorted the high/low beam switch and FFR is mailing one out.
