This is my first real post on this forum, after some activity on the other forum a few years ago. Life got in the way for a few years, feels good to get back to work on the car. No need to welcome me to the madness (I only go back to my detailed cost spreadsheet for a chuckle now and then), although I suppose welcome back would be appropriate.
I'll leave a longer (re) intro post when I get full rights, can post an avatar, etc...but in the interest in sustaining progress on the build, I'll just ask my question for now. This is an older complete kit w IRS, with the standard brakes that came with the complete kit at the time. There's a lot on both forums on e brake routing, and much there that I'll copy. The adapter bracket has a clearance problem with the e brake routing that was noted at the time, some used a button-head screw & counterbore for that location. My kit shipped with four standard bolts for this location, FFR indicates clearance should not be a problem...
But, always good to get feedback from those with experience on any specific questions, so here goes:
I can get the e brake cable in place without a problem, but when I push the caliper the cable will bottom out on the bolt head. I haven't loaded the pads yet, which might give me a better indication of whether I've got a problem. I'd like to know whether I have clearance problem now before I torque everything down. Thoughts on how to check and make sure?
Second question is about the cable routing near the axle...current plan is to pull it to the rear and under the LCA initially, then tie-wrap it on its way up and through the LCA, and then up and over the pumpkin. Getting up on top of the LCA immediately (and further away from the axle) seems like WAY too short a radius for the cable. Sound right?
From there I should be set...cables appear to be the right length, have seen Jeff's info on how to adjust length if needed, and Paul's background on using the Lokar fittings, etc. I haven't found the ebrake handle parts yet, but I checked 'em off on the inventory so its waiting for me somewhere
Photo is of the PS rear brake, taken from the rear center. Remember....newbie. If you can't see the photo just let me know, and I'll work on it. Thanks as always to the many helpful builders on this forum!
Untitled by John Ibele, on Flickr
