Results 1 to 4 of 4
Thread: Power Steering Hoses and Fittings
    Nov 2016
    Petaluma, CA
    Has anyone used Aeroquip AQP High Pressure hose (http://aeroquipperformance.com/lookup.html?supercat=12) and steel fittings for your power steering connections? I have the FFR power rack and KRC power steering pump. Thanks
    I had a friend use it on his LS 55 and had bad noise from the hose. He ended up using a OEM style rubber hose. Now it is quiet.
    Banned
    Loveland, CO
    I used it with my LS3 motor that has a Cadillac CTS pump and flaming River rack. It worked just fine.
    This is an easy one. Talk to Mark at Breeze Automotive. He has all the right PS hose fittings and will sell the hose to you by the foot. His stuff is Aeroquip and first rate. Highly recommended.
