Out of Sight Audio
Thread: Electrical connection to fuel pump
    Need some help with electrical connections.
    The plugs from my fuel pump donít match up with the RF harness.
    Any advice?
    That's the plug that drops right in to my 190lph pump. Which pump are you using?
    Mk4 #8861 2016 Coyote, TKO600, 3-link
    Delivered April 27, 2016
    *** Life curveball period ***
    Unconventional Builder Joee's Avatar
    Hatboro PA
    Might want to investigate what pump you have. I agree with initiator.
    Roadster 5294, 302 Comp XE276HR cam, AFR 185 heads, 650 Quick fuel carb, Air Gap intake 3.55 gear Best ET 12.14 @113
    YouTube Videos: Current performance - https://www.youtube.com/channel/UC7c...86xO3U4l4RtVMQ Older build - http://www.youtube.com/user/joeembery#p/u
    My Pics:
    http://s207.photobucket.com/user/Joe...?sort=6&page=1
    Tybee Island, GA
    I have a stock efi pump in my tank. Plugged right up to the RF
    20160820_114453 by D. R., on Flickr
    Videos are at: YouTube Videos
    Blog @ BuildaRoadster.com
    Quote Originally Posted by Joshua_vance25 View Post
    This is the connection from my Fuel pump
    That's the first time I've seen that type of connector on a fuel pump. Is that a donor pump or an aftermarket unit? Hopefully someone else who has experience with it can chime in, but you'll probably need to cut off the Ron Francis connector and wire up a mating connector. If you have trouble finding the mating connector and you know the fuel pump pinout, you could just select a new connector pair (like from Amphenol) and make it up yourself.
    Hatboro PA
    Or get the appropriate pump for early 90s Ford 5.0m. I would be very tentative rewiring the in tank pump.
    My Pics:
