Likes Likes:  2
Results 1 to 19 of 19
Thread: Show us your steering wheels
    I'm not a fan of the FFR steering wheel, so I'm looking for a replacement. My last "fun car" wore a suede sparco racing wheel (which I'm tempted to repeat), but I'm also intrigued by completely the opposite direction and putting a classic style wheel on there.
    I'm using 275 front tires, without power steering.. so the 15" wheel might help
    Or
    What have you got?
    Banned
    Loveland, CO
  3. Likes Geoff H liked this post
    Grant Wheel #692:
    http://www.jegs.com/i/Grant/470/692/10002/-1
    Jegs Quick Release Hub:
    http://www.jegs.com/i/JEGS-Performan...60722/10002/-1
    Chevrolet LT-1 / L-82 Corvette Valve Cover Emblem Fits Perfectly In The Horn Center Section:
    https://www.ecklerscorvette.com/corv...1969-1982.html
    You can see what it looks like about 10-15 seconds into the video:
    https://youtu.be/PCngiKoopkA
    Now That's Coooool!
    Nice wheel Steve.. I assume that quick disconnect required welding?
    Dave, that's a clever idea -- matching the steering wheel to the other wheels.
    Yes, it requires welding.
    I had my friend Ernie do the honors since he knows how to TIG and I don't.
  9. #8
    May 2013
    Gainesville, Florida
    What do you dislike about the FFR wheel? I agree that it sucks a bit as it comes. The half plastic rim is cheesy as hell and you're stuck with the FFR logo for a horn button. My solution was to order a "wheelskin" to match my upholstery (in this case black) which I easily stitched on myself. Then I filled the FFR logo on the horn button with JB Weld and made up a vinyl emblem to my liking. Pretty pleased with the slightly thicker leather rim and also with some accent color on the horn button.
  10. #9
    For me it was all about being easily detachable with an SFI approved release mechanism.
  11. #10
    John Tongish's Avatar
    Dana Point, California
    After installing Erik Hansen's electric power steering package in my MKIII, I realized I didn't need the bigger diameter factory supplied steering wheel to overcome the tire friction when parking and at low speed turning. So I installed the MEMO racing wheel, 1" less diameter, and flat on the bottom for easier entry.
    All is now good in my Yellow One.
    I can't believe I built it, and it runs!
  12. #11
    Senior Member Barrel's Avatar
    Aug 2011
    Mornington, Victoria, Australia
    http://www.accessoriesonline.com.au/...roductid=17122
    I found that I don't need P/S with a 15" steering wheel. I went with this. It's a straight swap.
  13. #12
    Quote Originally Posted by kraftee View Post
    I'm just not a fan of that style of billet on cars. Reminds me of the Boyd Coddington rod era. If I were younger with a bigger budget I'd go race theme again, but this time I currently prefer that '40 replica wheel for some classic style.
    I saw one for the first time last weekend, and assuming it was stock I also didn't like the 'sharp' aluminum grips on the back.
  14. #13
    May 2016
    North of sacramento Ca.
    Ford banjo wheel- 37 to 39
  15. #14
    Top Notch Builder P100DHG's Avatar
    Pasadena, CA
    I cancelled my wheel and hub and got a $90 credit now the search for the right wheel begins...
  16. #15
    Kingsland, TX
    I have the MOON GT Foam Grip Slotted Spoke Wheel (can't find the link for the 13"). To date I have four items for my '33 :: Wheels, Steering Wheel, Engine, and Trans!
  17. #16
    Feb 2014
    I used the supplied FFR wheel on my 33 Hot Rod but am not crazy about it either.
    This photo shows what I did on my latest project which is a 1940 Plymouth pickup truck. I wanted a classic Mopar wheel so I chose a "square" wheel from a 1963 Chrysler 300 "Letter" car. I had to modify the base as well as repaint it and did the leather wrap myself from a flat piece of goat skin. The right steering wheel can totally influence the whole mood or theme of the car.
    This post might just inspire me to find a better wheel for my 33 Hot Rod.
    Stacked33
  18. #17
    I have made a bad choice! I went for the 1940 replica wheel, liking the look originally, but now I’m gokarting it sucks. Having two spikes and a thin plastic rim just isn’t doing it for me. When I’m driving - even gokarting around neighborhood at 20mph - the wheel is flexible!! It’s flexing as I turn corners. No thanks.
    So I’m returning back to the sparco suede model I loved so much on my GT40. 13-14” and may as well look for a quick release while I’m about it. Which thread do I see others who have done this on the hot rod?
  19. #18
    Simi Valley, CA
    I don't recall seeing anyone put a quick release steering wheel into a '33, but Paul B. put one into his recent Type 65 build: https://thefactoryfiveforum.com/show...l=1#post399325 You can't go wrong following Paul's lead on anything, IMHO. Keith HR #894
  20. #19
    Ottawa Ontario
    I just put this on the 37. Billet Specialties 14" Vintec that I covered in blue leather. Scott
  21. Likes shmelty liked this post
