Results 1 to 6 of 6
Thread: Tire to body - rear
    May 2016
    North of sacramento Ca.
    Tire to body - rear
    How much are you putting between tire and body - with IRS - rear.
    Fairfax Station VA
    What dimension? Top of tire to underside of wheel well? Center of shock mount to outer edge of fender lip?
    Which IRS? I'm assuming 2015, but you know what they say about assuming...
    MK IV Roadster #8631
    May 2016
    Yes 2015 IRS Inside of tire to inside of fender at body.
    I don't understand the question. Picture?
    Banned
    Loveland, CO
    deleted.
    Richard Oben's Avatar
    Kansas City MO
    The problem is they do not ever rub at the top. They rub to the rear of the tire at about the 10 or 2 position. On an IRS 315s will rub the fender and the kidney panel behind the seat at the same time on full compression. FYI. Richard.
