Thread: The Best Sound Deadening and Heat shield Protection
    Mar 2018
    What do you think is the best way to make the 33 not rattle or vibrate so much and the best way to keep the heat out. Ive heard of so many products. Lizard skin is supposed to be pretty effective. Any opinions?
    Placitas, NM
    I bought the sound/heat insulation from FFR. There isn't a name of it.
    These are two separate parts, one for heat and the other for sound.
    Peel the backing paper off the heat insulation and stick it on the aluminum and inside the doors.
    Then do the same for the sound dreading material, it sticks on top of the heat insulation.
    They are custom cut for all of the areas.
    It wasn't cheap however FF had a 1/2 price sale on a lot of the options when I ordered my '33.
    One of the car club guys here had a Daytona and had some Fat Mat (FM) left over which he gave me. It's only 1/2 as thick as the FF heat insulation and doesn't have anywhere as much sticking ability as what FF supplied. That may be because the FM was over a year old, don't know as this was the only FM I've ever seen.
    I did this write-up about Lizard Skin a few years ago. It's a Roadster, but still applies to your build I think. That was the second build I've used it on and have done more since. Is it the best? I don't know. There are plenty of choices. But it's an option I like. On the road experience shows it works well.
    http://www.ffcars.com/forums/17-fact...xperience.html
    Nov 2016
    Petaluma, CA
    I have used a combination of Lizard Skin for heat control in the cockpit and covered that with Dynamat for sound deadening. I also sprayed the underside of the body and the underside exposed aluminum with Raptor undercoat. As others have said, not sure if these are the "best" products but they seem to do the job in combination with each other.
    Mar 2017
    columbus ohio
    Resto Mod Air has a new product out. We have ordered some to evaluate. I'll post my assessment once we have evaluated it. FYI they call theirs "Membrane"
